XM Commander install
sdtahoe
Does anyone have any pics of a XM Commander installed in a 95-98 chevy truck or Tahoe?
I just got mine today and trying to decide where to mount it. I was thinking maybe building up a plate and mounting it in the cubby hole (where the factory slave cd player goes). Another idea I had was to mount the unit over the rearview mirror.
Well I changed my mind and bought an overhead console off of E-bay and mounted it there last night (even though it was 0 F last eve).
The main unit is mounted under the dash and all the wires are tucked away out of sight.
Did you hook the commander up through FM mod or direct line input? I am sitting in my wife's 01 Tahoe now looking at potential mounting options and hookup options(shhhh, don't tell her :thumbs: ) I want to take out the factory tape deck in the lower console and put the commander in that location. I really don't want FM modulation though, I am having trouble finding an adaptor to use the aux input. Thanks for any help
I used the FM modulator as I have a 8 year old Pioneer deck with out any auxilary inputs. For you 2001 Tahoe you could use a Pie adapter to hook it up direct. My only complaint about the FM modulator is that the volume is lower than the other sources, but since getting XM I haven't listened to a CD and only listened to FM in the car wash teh other day.
Pie adapter
At the bottom of the wiring diagram page it makes an exception about AM/FM/singleCD headunits that have the tape player hooked up to the 9-pin port. I am not sure if that exception means that hooking up a XM tuner won't work or if it just won't work with a CD changer. Diagram page
Thanks for the quick reply.
It sounds like it will not work with a cd changer (the deck will not be able to control it). It would not hurt to e-mail them and verify priot to ordering one.
I will also be hooking mine up direct soon I found a new Pioneer deck on clearance at walmart tonight :thumbs: The audio bug had bit once again.... now after the deck is installed maybe new speakers.
Where can I get one of these XM Commanders?
I purchased mine through Circuit City's web site, they had the best price at the time and free shipping.
Finished the install on the 2001 Tahoe(wife's ride). Thanks for the help on the adaptor questions. I am very happy w/ the install and took a 5 hour(one way) road trip this weekend and LOVED having XM.
One more pic!! My only problem is that I now have engine noise when using the Onstar telephone. Any ideas to get rid of that?
    rayredbone
    rayredbone
  • Who's Online   2 Members, 0 Anonymous, 440 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
