I have a 2016 Sierra 1500 and I'm getting a "Service 4WD" message on the dash. The transfer case is stuck in 4wd. I've seen other threads that talk about checking grounds for corrosion or severed wires and I've done that. Everything is in cleaned up and connected. I took the truck to autozone to run the code to see if it was a C0306 for the transfer case motor and no code for the 4wd system came up.
The only code I got was a C0110-61 for the ABS Pump Motor Circuit. Message on this forum seem to suggest checking for corrosion first with this as well so I'll start there.
Anyone else had the "Service 4WD" message come up with no associated code?
It’s happened to me a couple of times.  I put in Park, shift to 4x4 low.  Let it cycle to that, then select 2 wheel drive.  That fixes my 2016 1500 Sierra.
Tried that, doesn't even attempt to shift. I'm not sure if the message disables it trying to shift or if it can't. There's no message about trying to shift to 4low or anything.
I also changed the brakes. I found one of the pins on the front caliper was frozen. I wonder if that caused the abs light. New bracket and pins on order. I'll test again after that's installed
    Chris80s
    Chris80s
  • Who's Online   4 Members, 0 Anonymous, 834 Guests (See full list)
    • Still $3.01 with even more places at this price
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
