Motorsports Photography
Z71
My new venture is Motorsports Photography and I wanted to share some pics. :crackup:
I'm still working on the website but to give you an idea.
My Site (Site is still being worked on):
Turn 1 Images
Right now it's a hobby that pays for itself and additional equipment. Then with luck and in a few years, I will be doing it to make a living.
I used to shoot film a few years ago doing the same subject but turn around was a bitch. Digital makes life so much easier.
d00d ... those are awesome. I'd (almost) give my left nut just to be at the track for the bikes! :wtf:
"Almost"?
Those kind of thoughts never enter my mind....Give up one of the boys.... :thumbs:
:lol:
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 827 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
