Anyone know how to disconnect the GM sensors from the trailering app? I was not happy with my experience using mine, so I went with an aftermarket TPMS system. Problem now is every time I tow, after about 10 miles I get a "tire pressure fault" warning because the system is searching for sensors that aren't there. I can find plenty info on how to set up the system but nothing of how to remove them.
    whenindoubtuseahammer
  • Who's Online   2 Members, 0 Anonymous, 387 Guests (See full list)
