Bumper Guards
It would seem my truck has a glass jaw. I tapped what I though was a snow bank and cracked the plastic part under the front bumper on my 03 Sierra. I got an estimate of $229 to repair it. Anyone know what the lower valance should cost to replace?
Can anyone recommend a bumper guard to prevent this from happening again?
miclri:
I don't know much about bumper guards, but I really like my RanchHand replacement bumper. See the link in my signature line.
When the installer removed my old bumper, I noticed it weighed maybe 30 lbs, and I could Flex it easily with my hands. It seemed obvious to me that a few-hundred-pound steel replacement was a good idea for the very reason of your experience. It also would hold up better in an bad accident. With the stock bumper, I feel like my radiator would be ruptured in a 10 mph collision. I am guessing somewhat, but I also suspect that a solid, steel bumper would distribute the impact in an off-center collision much better than the sqishy stock bumber. Further, the replacement bumper privides a better entry angle when driving over rocks, and when I am off-road, I can drive over bushes and small trees without consequence (I know it's not nice to hurt trees, but we have billions too many trees in the Nat'l Forests in Colo - which is why we tend to have especially violent and widespread forest fires).
A bumper guard seems a little more like a cosmetic fix to me, but they are certainly an improvement over having just the stock bumper, which can be broken by snow. In fact, now that I think about it, if I had to drive an entirely stock Sierra/Silverado, the weaker-than-a-Yugo bumper would be the only thing to concern me more than the tiny tires and wheel wells.
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 716 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
