Superchips or Hypertech??
Was wondering if I should purchase a Superchips programmer or the Hypertech for the wife's '03 Tahoe. What do you think? Don't they do different things? Superchips has more options?Thanks for any input. :eek::seeya: It's a Z71 Tahoe 5.3L
Don't know. The Superchip programs differently how? Is the Superchips all thru the RPM's whereas Hypertech is only WOT?
I have known many of the people at Hypertech for a long time.
I raced with some of these people since the 70's and I know they
are more than qualified to do their jobs. I don't know where it got
started but, to set things straight, their programming is not
just WOT. I have been in on many tuning sessions over there since
we are in the same county. They have used several of my cars and
trucks for testing. Any of you with a HPPIII for 6.0L 2002 Model, 5.3L
for 2000 model, or 8.1L for 2001 model are using settings patterned
after my truck. I don't think they only used my vehicles but they were
the first tested ( I bought early in the model year).
Hypertech programmers are conservatively tuned so they will work
MTBE, non MTBE, 87-93 octane and fuel in some parts of the country
that are low quality.
Sometimes they are slow to get things to market because they are
quite thorough.
Don't get me wrong, I don't know if they have the fastest programs
and I'm not advertising for them (they have plenty of money for their
own ads) :devil: but I do know their's will be a program that is simple to use
and will work well in most cases.
I have not even tried the other programs so I can't tell you how they
compare. I just know that mine have always worked well.
Before too long I hope to purchase a Westers and see how it works.
I want to keep original PCM and do same day testing a Memphis Motorsports
Park. I will post the results afterwards. :thumbs:
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 557 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
