So this is where we say hello?
SOM Truck
Alright then... hello. :seeya: LOL.
So far I can say it's a great site. I came here looking for some information to do some intelligent modding on my truck and it's turned out to be a great resource. I was supposed to leave this d**n truck alone and just use it as a daily driver and tow vehicle in stock form. Yeah well... that ain't happening. All my friends knew I couldn't keep her stock though. Luckily it's so d**n easy to mod these Duramaxs to make power! :eek:
Anyway, just saying hello and thanks.
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 778 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
