Is the warning to change the engine air filter from a sensor or is it just based on mileage or time?
52 minutes ago, redwngr said:
All 3 use sensors.
That is not what I expected to hear.  Although my truck is a 2020 it only has 15,000 miles on it and I have the warning to replace the engine air filter.  I don't drive in dusty or any kind of extreme conditions.  I will do it but I find it hard to believe it really needs to be replaced.
How does it look?
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 1,132 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
