SOLVED! Turns out it was just the starter relay. Swapped it with the trailer light relay and it fired right up, no hesitation.
2018 3500 duramax LT. 130K
This happened on and off a few months ago, now it's starting to be almost every day.
Get in, turn key to on for a second, then turn and holt to start. All the dash lights go out and nothing for 2-5 seconds, then the engine cranks over and fires up. A couple times now it has half started and died, then cranked again and started.
My thinking is the started is having issues, but concerned it could be the ignition switch or something.
We had problems with the ignition not unlocking with the OEM key (2 replacement keys seem to work fine) but we haven't used that key in over a year.
Starter looks like kind of a PITA to install, but not terrible.
Edited by Evan Martin
Solution
Usually a connection issue if all the dash lights go dark.  A bad starter shouldn't cause everything to go dark.
I tend to find problems with the battery cables or grounds. I'd be testing the cables and cleaning all the connection points you can find.
    appletrav
    appletrav
  • Who's Online   3 Members, 0 Anonymous, 344 Guests (See full list)
