Selling this set of 2024 Denali 2500HD taillight's, I have a set installed on my 2023 Sierra SLT 1500 they do work but (it does hyperflash haven’t been to dealer to get the programming needed to stop it “box delete” is what I need and it’ll fix the hyperflash) asking 1000$ picked up or 1100$ shipped (if PayPal add 3%)
I have video if u want to see them in video. These are WAYYYYYY BRIGHTER THEN 2023 Denali taillights IMG_2837.thumb.jpeg.49c54c53b874deb35f091504b2397dba.jpeg
Edited by Frankielozano214
If you’re adding to a Sierra 1500 you’ll need to buy a conversion harness (285$) and two OEM LED taillight harness for the 2024 taillights (124$ each) for the swap. I bought my OEM LED harnesses off eBay for 77$ for the pair free shipping
  • Frankielozano214 changed the title to 2024 Denali 2500 HD OEM LED Taillights
  • 3 months later...
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 393 Guests (See full list)
    • 2013 5.3 still to this day calls for the PF48 filter.  Which as a 15psi bypass pressure.     There is a TSB, 17-NA-157 that talks about the PF-63 and PF-64 filters which have a higher bypass rating of 22psi.    TSB HERE - temp.xml   "Beginning in 2012, the oil pumps began to regulate main gallery feedback instead of pump out pressure. This means that the oil pump now does not begin to regulate until pressure is built up to the main gallery. This change reduces the amount of time it takes to provide oil to the engine bearing and lifters during extreme cold start conditions.  Main gallery feedback oil pump control systems are present on the following engine families which use Spin-on oil filters: Small Gas Engine (SGE), Large Gas Engine (LGE), High Feature (HFV6) Gen2 and Small Block Gen5 gasoline engines. These engines with the main gallery feedback oil pump control systems are factory built with an ACDelco® oil filters"   It also calls out what engines use those filters.  The gen 4 small blocks were not on that list (LMG, LC9, L9H, L92, L94, L20, L96).  Gen 5 small blocks use the higher pressure filter.
    • To me it honestly makes zero difference what filter you run. It's not a race engine, just a truck engine that's mostly bumming highways and it just needs a filter that filters oil.   The filter used to be a 7060 and the long version was a 7045. Now it's the newer updated filter that the K2XX trucks and newer run, the 100255 I believe if we are using napa numbers. Any of those filters is going to do the job.   I wouldn't overthink it, to me it makes no difference because those first filter numbers worked for 18+ years before the spec suddenly changed.
