04 1500 RPO C5H (6900 GVWR) ?
RPO C5H = 6900 GVWR.
also C5S = 6600 GVWR.
I don't see these capacities mentioned anywhere.
Can anyone tell me anything about these options?
I am about to order, I think, the following:
04 1500 reg cab long bed 4x4 4.8 5 speed
Thanks.
You can get these GVWR options but they require quadrasteer. the 6600 is for 4x4 and 6900 is for 2WD. The 4WS is only available in LS and LT badging.
    bellssn690
    bellssn690
  • Who's Online   3 Members, 0 Anonymous, 706 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
