Lund Hood Deflector
Just bought a stainless steel hood deflector for my 2001 chevy silverado. I have a annoying noise now though. Sounds like someone is tapping on my glass and it only does it when I am going 55 or over. Has anyone experienced this and what is the remedy to fix it?
That's exactly the problem. Your deflector changed the way the air flows over your hood. Here's the fix
This has happened to every late model truck / SUV that I've had after adding a deflector
