your aftermarker 15" wheels...
looking to get some new rims/tires soon but i want a set of aftermarket
steel wheels to replace the factory 16" wheels. im running 165-75's bfg at's
now so i figure id have to go w/ a 31-10.50 tire to keep the size close. not
sure on BS though. i want the tire to stick out farther than stock but no more
than1/2" out of the wheel well. what are u running and if you can get some
pice that would be great! btw i have a stock 4wd 96 4dr tahoe.
You can put 15s on OBS 4x4s, trucks anyway.
The Tahoes do have bigger back drums, but I don't think they will have a clearance problem either.
A lot of people here run 15x10s with around -45mm offset. They stick out quite a ways though.
That sounds about right.
I was looking at some rims about 6 years ago, and I have drank since then......So it's kind of hard to recall what I was told.
i got a set of 15x8 on 32" tires..i love them. lil' (i emphasize lil') rubbing. why do u want a stcok sized tire..they look soo small. trust me, i had a 30/9.5/15, hated it!!! but i sold those rims off.. the set i currently have are 32/11.5/15 and those are just perfect!!! they give it a nice wide stance, stick out about 2" total. remember, ur back will be 2" inwards compared to ur fronts. i have pics on my website, i think it is page 4. go check them out.
pics
but i think if u go to Discount Tire, ask them what the best rim size is for u...
they should help alot!
Aj
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 901 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
