Hello Everyone,
Thank you for letting us join your forum!  We just signed up as a member vendor and wanted to introduce our small business, Turtleworks Engineering, out of Englewood, Colorado.  We have always driven Chevrolet or GMC trucks and got our start designing a product for a Chevrolet truck.  All our products are made in the USA.
Anyway, we will be posting more about our company and offering free products for review, but we just wanted to say hello and thanks again!
  • 7 months later...
Hello, Checking to see if you have any plans to develop a bracket for the GMT-800 series trucks.  I have a 2007 2500 HD Classic and would like to install the NOCO GCP1 plug assembly.  I am willing to help with fitment feedback if this helps you with the design.  Thanks.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
