Dear all,
I’m a new member. I don’t know my post belong to which topic on the forum. Please, admin, can you move my post if you see fit? Recently, my 2018 Chevy Silverado 1500 LTZ 5.3L V8 65,000 miles started having a weird sound. I recorded the sound. Please help me identify the problem. Recent transmission fluid changed. The sound only appears at low RPM and around 20-30 miles driving with really slight gas applied or from a stop and applying a really slight gas, then it is gone after 15 seconds. Please help!!!
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,071 Guests (See full list)
