Oops! I accidentally posted the same technical post twice here. I apologize – since I can’t figure out how to delete it, I’ve decided to turn this into a quick intro instead!
Hi, I’m Jason – a newbie with a Chevy Silverado ZR2. Right now, I’m researching how to make my ZR2 not just tough, but future-proof (yes, I’m that guy…).
I'm looking for budget-friendly modification kits, underrated useful items, or just some of the mistakes I've made. Let's share tips and help each other avoid costly errors.
The content below is a duplicate. Feel free to discuss if interested; otherwise, please ignore.
_____________________________________________________________________________________________________________________________________
Hey y’all,
So I’ve been lurking on these overlanding threads and recently found something that’s got me eyeing my truck’s messy cargo area… A basic modular rack system (attached below). It claims to let you add straps, hooks, tool organizers… basically build a custom storage setup over time. But as a newbie, I’m stuck on a few questions:
·Durability Test: Has anyone used these basic rails on rough terrain?
·No-Weld Setup: It says you can mount it without drilling? My garage tools are beginner-level (screwdrivers, a drill, and hope). Any tips on DIY-friendly installation?
·First Add-Ons: If I start with the rails, what’s the must-have accessory to prioritize?
Edited by Jason_Overland
    zibzer2
    zibzer2
  • Who's Online   6 Members, 0 Anonymous, 806 Guests (See full list)
