So I have a 2021 GMC sierra 1500.
Back in July I put a 6in lift with 35x12.5, bumpers, lights, winch, sliders.
After a few trips to Colorado, Utah, Arizona, and Nevada.... I've realized that I want a lot more from this truck.
There's almost no aftermarket support for my truck other than what I've already done. No e/air lockers(except what is now offered in the AT4X models) , no real trac bars (other than the shiny ones you see on mall crawlers)
Im looking to take my truck to the next level, full length skid plates, beefy trac/anti wrap bars, high clearance shock mounts. But looking forward I'm trying to determine which will be the most suitable option for my long term goals. Im not sure if I want to do all this work to an axle that might not be under this truck for the long haul.
I want to build a serious trail rig/ overland rig. Part rock crawler, part overlander. So here's what I have in my head. I have the factory 1/2 ton axle its an AAM SU7. I dont know anything about it, what spline axles, how strong or weak it it, ect. So I was considering swapping to a FF 1 ton for the rear...
Because I want to run 40s with portals, and e/air lockers.
But here comes the hard/ expensive part. What do I do with the front?
I would prefer to stay IFS but I dont know who makes 1 ton IFS carriers. But it would have to be one that has some aftermarket support.  I want e/air lockers for both front/ rear.
Beyond that the next phase would be trying to figure out how to make all of this work with my ecu/tcu/bcu.  These trucks (2019+) have a lot of checks and balances to maintain or they just chit the bed and go into limp mode.  I realize this covers a lot of topics in one post, but im trying to draw a plan on how to accomplish what I want.
Thanks for anyone who is able to steer me in the right direction.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,270 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
