I have a crank no start I resealed from the heads up and put a new 4l60e in my truck it ran before I did all this not crank no start I have power to both sides but no spark on any of the 8 plugs I’ve checked the ohms on the black wires to the coil pack rails and I have 10 ohms I need help put in a new crankshaft sensor still don’t work I had trouble putting in transmission tube but got it in and on the back of the motor was a ground that was nicked but I cut it and put a new end still no spark to the spark plugs?!!!! Please help
you might update your account's signature to include what year/make/model/engine/trim level your truck is.
check that the wiring harness along the rear of the engine wasn't damaged w the trans replacement, then that the grounds to both heads are good (both the cables are good, as wel as firmly bolted in place). then check for codes.
    Afennell19
    Afennell19
  • Who's Online   1 Member, 0 Anonymous, 685 Guests (See full list)
