My son and I have swapped the original 4.8 Vortec to a used 5.3 GM crate with ~100,000 miles. Do I need to order a brand new PCM/ECM VIN programmed and updated from Flagship One or can I have my old unit tuned? Pardon if I'm using the incorrect terminology but we decided to use this project as father and son.
If I purchase a new unit, will I need to have it tuned? Basically what are the next steps I should take from the electrical side as all other mechanical parts have been finished.
Thank you all.
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 701 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
