Just published- a new Pro Tip covering a clearance issue affecting 2021-2025 Tahoe, Suburban, Yukon, and Escalade models. The factory routing for the driver's side rear brake pad wear sensor wire can allow it to rub directly against the spinning half shaft boot, eventually tearing the rubber and causing a grease leak.
The official fix under Bulletin #25-NA-109 is simple, a revised bracket and a tie strap, but it's crucial to catch it before the boot is destroyed.
Read the full article and see the diagnostic photos here: https://www.gm-trucks.com/gm-suv-brake-sensor-half-shaft-boot-damage/
    Enduro73
    Enduro73
  • Who's Online   1 Member, 0 Anonymous, 1,711 Guests (See full list)
