Simplest way to get DVD/screen for my truck?
Hi all,
What is the simplest way to connect a DVD player and an LCD screen for my truck? Do I need a special harness? I have steering wheel audio control buttons and Onstar as well, if that matters. I'm very new at this mobile audio/video stuff, so any pointers are appreciated.
Thanks!!!
Guest loneranger
I heard that for 03+ Silverados, installation can be difficult because GM somehow made it harder for the aftermarket to change the stock system. What exactly is different between 02 and earlier vs. 03 and later trucks?
Thanks!
Thanks!
The 02' and earlier radios received power from the truck and had a turn on accessory wire that told the radio when to turn on or off. The 03' and newer radios use a data bus to do the same thing. The new radio has no accessory power wire meaning the power wire to the radio is always hot and the BCM tells the radio when it is ok to be on or off.... When I changed out my 03' radio for aftermarket I purchased the chime/data bus device that would give me the chime feature back and would communicate with the data bus so I could retain the power on feature (radio remains on after the truck is turned off for 10 minutes or until the door is opened) And the new radio has a line in so I can easily add a device with out using the dreaded FM modulator
Hope this helped
Matt :thumbs:
Thanks!
Hope this helped
Matt :thumbs:
Did you use any component from PAC audio?
Thanks!
Thanks!
Hope this helped
Matt :thumbs:
Thanks!
I purchased my data bus interface and steering wheel control adapter from Crutchfield. This is the pn for the data bus interface Metra VT-GMRC-01 GM Class II Data bus Interface Link and the steering wheel control interface PAC SWI-X Link
Matt
    RangerRick17
    RangerRick17
  • Who's Online   5 Members, 1 Anonymous, 608 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
