new noise from behind the dash?
Hi -
A new noise has developed from behind the dash on the driver’s side. Seems only to appear when the engine is warm, and when you gently apply the brakes or accelerate slowly. This came out of nowhere. I don't think it's the brake pads seeing the Escalade has less than 20K miles on it, but it's a medium pitched friction/rubbing sound. It also gets a little louder when you go over bumps. If you turn up the stereo to a low volume you can’t hear it. You also can’t hear it at above 30mph – it’s pretty faint. Any ideas before I start tearing it down?
You input is appreciated.
  • 4 weeks later...
I had a noise similar to that in my 2003 Yukon and I took it to the dealer and they said they had to replace the instrument cluster. I don't know what part of the cluster was bad,just that they said it was in the cluster. Is is still under warranty?
z71side - Thanks, I think you're right. I can’t think of any other source of where the problem may originate I thought that the culprit could be the brakes but they checked out fine. Ironically, the noise has since disappeared since I posted this.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 901 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
