service eng. codes 35 & 36
i installed a powerdyne throttle body 1 inch spacer on my 95 gmc burb 2500 7.4l TBI
after about 80 miles (while idleing, i put it into gear and my service engine soon light came on).
i checked the code's (ground a & b) it blinked 35 and 36.
the air sensor and rpm idle sensor...
i figure the spacer isn't hurting anything, but how do i get my service light to stay off.
i gained almost a full MPG (.9) so i want to keep the spacer.
are there any remedies other than black electricle tape over the light???
thank you.
any replies (private, EMAIL [email protected], or posting.
g3ride69 :sigh:
Dumb question,but did you plug the IAC connector in all the way :sigh:
You can also check for a vacuum leak,the bolts may have loosened ...a leak would also trigger the codes...also check to make sure that a vacuum line didnt pop off or loosen....if all else fails...disconnect the batt. negative cable 4 a minute to clear the codes and see if they return.....
PS...welcome to the board :)
    ballencd
    ballencd
  • Who's Online   2 Members, 1 Anonymous, 448 Guests (See full list)
