Slight stumble off idle
My truck has a slight stumble when I initially hit the gas from a dead stop. It's worst when cold and barely noticeable when warm. Oddly, it does not happen during hard acceleration from a stop.
Where should I start looking?
Hi -
Could be the throttle body. I know that when mine was dirty my 6.0 was doing all kinds of crazy things: rough idle, wanting to stall at red lights, hesitation at initial acceleration... I cleaned the throttle body and 20 minutes later the SUV was performing perfectly. By the way, my TB had to be cleaned with only 14K on the odometer.
I didn't pull mine. I just unhooked the hose and sprayed TB cleaner in and around the TB. I also opened the butterfly valve and sprayed both sides of the blade. I waited a few minutes, gently wiped off the gunk and reattached the hose. Worked like a champ.
Some folks remove the TB...I would try just cleaning it and running it, first. If it's too dirty you may need to remove it, though.
