Transmission fluid leak
Hi,
I have an older Silverado (1998) K2500 with only 43,000K. I pride myself in the care I take with maintenence and appearance of this truck. Yesterday I noticed two or three small puddles on my driveway where my truck is parked. It appears to be automatic transmission fluid. I looked under the truck and saw small droplets forming at the bottom of the engine. I wiped off any access fluid I could find and moved the truck to a different spot for the night. This morning there was one more small spot. Not as bad as before. I just recently moved and had the truck loaded a few times, but did not experience and trouble or leaks until the other day. Any help or suggestions with this problem will be greatly appreciated.
Thanks
Dan
Did you see this @ the bell housing "WEEP HOLE" or were there witness marks(tracks from the fluid) coming from the pan gasket area..or @ the engine oil pan? :wtf:
Just a thought here. Does the Transmission dip stick lock down and seal good at the opening. If not it could come from there.
    ballencd
    ballencd
  • Who's Online   2 Members, 1 Anonymous, 448 Guests (See full list)
