Roush team may be looking to supersize
Elwood
By Lee Spencer - SportingNews
Is there more to the Roush-Yates merger than sharing the Ford Racing Engine program? Garage sources say Roush Racing has offered to purchase Robert Yates Racing. That would lead to a seven-car Nextel Cup superstable for Ford -- defending Cup champ Matt Kenseth, Mark Martin, Kurt Busch, Greg Biffle and Jeff Burton from Roush, and former Cup champ Dale Jarrett and Elliott Sadler from Yates.
The Yates camp says the rumors are rubbish, but I'm unconvinced. RYR has had to calm the concerns of employees, who have witnessed several longtime workers dismissed in recent weeks. Robert Yates, who turned 61 last month, probably would like to spend more time on his boat in Florida. Plus, with the possibility of Toyota entering the Nextel Cup Series in 2006, it makes sense to pool all the Ford resources together -- similar to what General Motors did by combining the Pontiac and Chevrolet programs.
They already share stuff through the engine program so I would not be suprised to see this happen. The Wood Brothers are bascially teamates with them also already.
So in other words, He could own another 5th of the field :D
Yates needs to stay seperated from Roush in the aspect. Roush can barely keep his 2 cars that run good running. He doesnt need 2 more drivers to screw over.
    rayredbone
    rayredbone
  • Who's Online   0 Members, 0 Anonymous, 510 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
