04'Engine Oil Life Monitoring?
I just bought a 04 Silverado 4X4 and the window sticker states;Driver Information Center and Oil Life Monitoring System,Under the Standard Equipment.
I was checking the manual and my truck does not have the buttons for the DIC,So how do i clear the info when I change my oil?
Did they forget to add the right steering wheel at the factory?
Steve :thumbs:
I think it's turn your key to the acc and then press the gas pedal down 3 times. I think there is other posts on that on here. Try doing a search on it.
Its stated in the Owners manual how to do it but Bishop nailed it. The 03-04 silverados never had a button for the DIC.
Let's clear that up just a bit. The fully functional Driver Information Center, with steering wheel buttons, is an OPTIONAL item for the '03s and '04s. Through this Center, one can reset the oil life monitor, in addition to the accelerator pumping method.
The 03-04 silverados never had a button for the DIC?
frdfandc
On page 3-54 in the 04 Silverado manual they show DIC buttons on the steering wheel,4 of them.Trip,Fuel,Personalization and select.
I found it after reading further into the manual. pg.5-21
Steve :thumbs:
    bellssn690
    bellssn690
  • Who's Online   3 Members, 0 Anonymous, 905 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
