Water problem
HeyJoe
Anyone have any ideas what my problem is here? :flag:
Ok, just kidding, that's not mine. A friend just sent me the link to a posting on another forum, at this page.
If that's your truck, sorry pal. I'd have a long chat with the friend who borrowed it.
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 630 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
