MSD Blaster Ignition
I ain;t got any pics, but it's brand new, had it for close to a yr. Got it to put on my truck, never got around to it (I believe it'd work), will work great as an add on to older GM trucks. $45 and I'll pay shipping even
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,163 Guests (See full list)
