Iam stumped! help me diagnose an interior noise
Ok, this one has me stumped. My truck is amost a year old. 2003 1500HD 6.0. For about the last 3 months I have been getting this strange constant sound from behind tach/speedo cluster. I can best describe it as a constant hollow humming sound. Here is what I have noticed so far:
1. The sound is always present and you hear it at idle or when driving slowly.
2. You can not hear it from the engine compartment side. Only present from inside.
3. Increasing the RPM at idle has no effect on it. It does not change at all with rpm
4. I have messed with all possable settings of the HVAC and nothing will make the
sound change.
5. I have heard of some people with trapped air in the cooling system causing
strange sounds from behind the glove box. I did attempt to do the standard
bleeding of the cooling system by letting the truck warm up with the cap off
the surge tank. I did get some bubble out of the cooling sytem but not much.
I did this three times, and no change on my noise from behind the dash.
6. I also notice that the noise is slightly present on start up and get lauder as the
truck warms up.
7. It has nothing to do with the radio/speakers either.
So what do you guys think? any ideas??
Thanks for any input you have.
It is the litle drive motor that controls the position of the tach.
The only way to verify it is to sweep the gauges with a scan tool that has that capability. You'll hear that same hum for the couple moments that the gauge sweeps.
It should be covered under warranty, but you'll need to replace the IPC - Instrument Panel Cluster. I've replaced at least 1/2 dozen for this very concern.
Hope this helps. :thumbs:
Thank you mr. gmtech. I now have some good info to give to my dealer to check out.
That very well could be it, cause I know when the truck is turned on and off, there is alot of chater from the same location for a brief moment.
Thanks again.
    ballencd
    ballencd
  • Who's Online   3 Members, 1 Anonymous, 664 Guests (See full list)
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
