Hey all. I want to add some power to my '03 C2500HD Crew Cab (with the 6.0 L). I have already decided on an ATI Procharger with the intercooler. Can anyone suggest either a good Tri-Y header or a limited slip differential (I want to keep my 4.10 gearing there)? Or, just a good place to look for them? I am not having much luck on the net, my search results are pulling up way too much unrelated stuff.
dynatech makes a complete system for your application. thorleys make the tri y's. a popular set up in the truck world now is asm headers. eaton is the best posi unit. you can find a lot more info at www.ls1tech.com
A Try Y is a sweet header but I do not know how much it will help with a blower though as the forced induction kinda defeats their scavanging action. Maybe just some good flowing down pipes and mufflers.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,155 Guests (See full list)
