Seat Fabric Defect TSB??
At the bottom in the front of both the Drivers and Pass seat where the Adj lever is the fabric where it is hooked to the metal cross bar of the seat keeps coming unhooked. It has a plastic clip channel that I can reinstall over the metal bar but within a few days the front fabric is hanging loose again.
Its an 03 RCLB Sierra 13k miles, was curious if anyone has had this happen and if a TSB exists on a fix. I figured I can RTV the clip channel and reistall it but thought I would chk here first. I would like to keep it out of the dealer if possible as its never been back and its a crap shoot on what they will hose up in the process of a fix!
Thanks for the help in advance,
Terry
My driver side seat had the same prooblem. After closer inspection I noticed that I was only rehooking the front edge and not the side (closest to the console). After I hooked the side and front it hasn't come loose again.
I checked the side fabric and its all attached and clipped on fine. So it appears to be just an issue on mine with the front.
Anyone else out there have this issue now or in the past....or am I just "special"? :seeya:
    bellssn690
    bellssn690
  • Who's Online   5 Members, 1 Anonymous, 857 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
