How do I know???
How do I know If I have a 8.6, 9.5, or a 10.5 ring gear axle?
I have a 99 Z71 nbs, 1500, with the 3:73 gears.
Reason I'm asking is because after you do a fluid change, you need to be filled to 0.6 to 1.6 inches below the fill plug for a 8.6 and 0.4 inches below the fill plug for the 9.5 and 10.5.
Thanks.
Ok I think I found the answer.
The 1500 uses the 8.6 and the 2500 uses either the 9.5 or 10.5. Found this according to my owners manual when it addresses how far below the fill hole, the manual said the 1500 is 0.6 to 1.6 below the fill hole, which corresponds to the 8.6. It said that the 2500 is 0.4, which is either the 9.5 or 10.5.
Also for those wanting to know the transfere case Autotrack blue stuff is only like $7.00 a quart from my dealer. Not as bad as one would think. (No I'm not putting this into the the front differential - changing this along with the front and rear all at the same time.)
8.5-8.6 are 10 bolts. These are in all 1/2 tons.
9.5 is a semi-floater. These are in some 3/4 tons.
10.5 is a 14 bolt full floater. Some 3/4 tons and all 1 tons.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,071 Guests (See full list)
