What does these go to?
The past couple of days I have hear a rattle in the drivers door going over bumps and such. Too it apart today and found these laying at the bottom of the inner door? I can't find what these might have went to , any ideas?
Have manual windows, keyless entry, everything on the door work fine, so dont know what these went to? maybe a part of a aftermarket power window???
{look at pictures in next post}
sorry the pictures are not too good of quality, but that coil look as if it went between those 2 plastic pieces......
Help me!!!
They look like a part to the power windows. It looks like part of the piece that the cable runs through then gets wound on a drum. The spring(coil) is usually in there to help hold the tension and then aid in spinning the drum the other way.
It is only a guess. I've seen something similar on an import with the window actuator. Thought that there would be something to fix in it but as it turned out you have to buy the whole piece.
Anyway, did your truck have aftermarket windows installed at one time?
Thanks for some light on this?
I'm not sure if this truck ever had aftermarket power windows!! I got it with 45K on it, there are not extra wires in the door area, or any cutting to the panel. When I added the power windows the inner film on the door(weather protector) had never been messed with. i'm at a lost, i guess i could remove the pass side door and feel around.
They look like parts of the window regulater,relief spring and cover to be exact...
Is the window a little harder to wind up (close)? The spring applies tension to assist in closing the window,it counters the weight of the window...kinda like a garage door spring....for example
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,192 Guests (See full list)
