4x4 not working
Hey,
I have a 89 Z71 4x4, transfer case is engaging, but front drive line is not.
What would cause this? Is there some sort of solonoid?
Im not to familiar with these trucks, everything else I have had, has been full manual.
Thanks
Front axle uses a thermal actuator. It's not working. Go to a GM parts counter, tell them what you have and the problem and they should sell you a retro-fit kit to put in a motorized unit.
No prob. That's why we're here, to help each other out. Just passing along info learned from reading newsgroups over the last few years...
You might want to look into a after market manual kit for it too. GM used a couple of different accuator types there and thermal is the most resent as I recall.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,113 Guests (See full list)
