I purchased the K&N FIPK kit and installed it in less than an hour. I really like the throttle response and sound differences :thumbs: . I don't keep up with the MPG, so I don't really know if it makes a difference. I do have some pictures of the install...
Here is the link to where I bought it from...
K&N FIPK at SFX Performance
Hope this helps...
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,163 Guests (See full list)
