Hello
Midnight
I registered here a while back, but then never made it back around.
I'm from East Tennessee, just north of Knoxville.
I have a '99 Chevy Silverado Z71. It's my 3rd Chevy truck, the first two were S10's.
Anyhow, just wanted to say hello.
Thanks! I go through Sweetwater every now and then. Was down there a couple of years ago when they had the "Affair at Philadelphia" civil war reenactment. I also stop in at the flea market down there occasionally.
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 701 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
