Speed sensivtive steering
I have speed sensitive steering on my '98 Yukon and was just wondering what it is all about. My truck is starting to drift a little in my lane at highway speeds. I know I need new shocks wondering if this speed sensitive steering is also a factor, or maybe should be doing the obvious and checking all rod ends and ball joints. :sigh:
Speed sensitive steering or VSES (Variable Speed Effort Steering) is designed to make steering in parking lots, etc. easier, and to not be so sensitive at highway speeds.
The power assist is controlled by a small valve on the back of your power steering pump. It receives input from a VSES module. THe module factors the vehicle speed, and compares it to steering wheel speed. There really are only a couple parts - the vehicle speed sensor, the handwheel position/speed sensor, the variable speed steering valve, and the module to control it.
90% of the time the problem is in the handwheel speed sensor, and there is a code that can be read to indicate a fault in that sensor.
Hope this helps.
So could this cause my drifting at highway speeds??? Also I have one of those $150 scanners you get at Auto Zone, don't imagine this tool would pick up the code if this thing was a problem?
More likely it would cause a condition that would make your steering wheel very touchy. Just barely turning to the right or left would feel like you are oversteering.
More likely you have a tire or alignment problem.
Always check your tire pressures first, set to pressures listed on driver's door. Then drive again. While rechecking your pressures, lookat tire condition, maybe it is time to rotate your tires. Check especially for "chopping" on the inside edge of the front tires.
If all is good with pressures and condition, have the front end inspected thoroughly. And make sure it is well greased.
If still everything looks good, it may be time for alignment. Let the alignment shop know what it is doing so they can address that concern.
Hope this helps.
Tires are good, wearing nice and flat, I rotate them every 8000 miles or so. Front end is tight and was greased a couple thousand miles ago. Might need an alignment but at slow speeds truck does not pull and like I said tires are wearing as flat as can be.
I did notice last night though that it does act like I am always over correcting myself at highway speeds. Truck also does have some bounce over uneven spots that seems to unsettle the truck, needs shocks bad.
Does your truck have a steering stabilizer?
If so, you may need to replace that as well when you have your shocks done.
Hope this helps.
I have a similar situation on the highway. When crusing at 60 - 70 mph through a long sweeping turn the steering wheel will all of a sudden turn much farther than the amount I was holding it at. It's like it shifts from firm to soft very quickly. The same as if someone would jerk the wheel while you are driving. I almost lost i a couple of times.....added a steering stabilizer....helped a little.....used lucas power steering additive.......better but still not firm enough. Is this a malfunctioning speed sensitive steering unit. Can it be removed????? :thumbs:
Same problem on my 97 Seirra!!
When I turn the wheel in a corner... it just seem to let go and turn more! Not a big deal to me as I am use to it... just worry about it if my wife drives it or on wet roads!!
Where is the control mounted?? Any chance of a digital pic?? :chevy:
Here's another thing I have noticed recently. When turnning and very low speeds forwards or backwards I get a growling noise from the steering box area. Ant thoughts on this one??
    • $5.19 for regular...
    • My office is slowly filling with Blazer parts. Getting ready to do the big bang of repairs. Intake (second time), water pump, radiator, hoses, and I'm going to re-seal the timing cover where someone went hog wild with silicone. Might as well, because I don't think that's done right.   There's a local tow yard that I didn't realize also has quite the inventory of junk vehicles. This is an old school junkyard. No waivers. Cash only, you were never here if anyone asks. Don't piss off the owner, or you'll end up in the back of one of those cars, headed for the shredder. And if you see something, don't snitch. Cars stacked double high, wasps nests, trip hazards and junk everywhere. I found a few little odds/ends for my Blazer. The $20 I spent was worth the experience alone. But I was never there. What yard?   I officially love/hate this truck. It's so out of my wheelhouse, roughest vehicle I've ever owned. Every. single. repair. -is so hard-fought, everything that can go wrong, goes wrong. Currently in a hate phase, and kind of wish I was closer to sending it down the road with a lucky new owner, to be honest. Preparing for the day when I tear into this thing...lots of pre-funk with Ibuprofen.   Rock Auto sent me a bad reman rear wiper motor. It was a bear to install. The tailgate in these things has about eleventy-billion fastners and pieces and things that need to be uninstalled/moved just to access the shoddy rear wiper motor. The casing on mine was cracked clean through, btw. Nice, GM, nice. SO I got this new motor installed, hit the switch, I see it wig-wag (without the arm installed) and think I'm golden. Reassemble everything. With the wiper arm installed I gave it one final test. Time to clean up and take the other half out to dinner, collect a paycheck, right?   Nope. I hear the plastic worm gear stripping as the arm hung up. Just like my broken motor. Weak/old and shredding itself internally. I can assist the arm and the range of motion is normal, and it parks correctly. It just doesn't have the poop to actually sweep the arm with a blade on it. Oh, hell. Turned the key off and shut the shop door behind me. I get to do that over again, too.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
