Aftermarket center console
i'm looking for a decent seat console for my '01 2500 HD. i've looked around town and on the net and can't find anything decent. can anyone point me in the right direction on this. i need on that just goes on the seat and not over the front of the seat.
tia,
phil
whats the seating arrangement? is this for a reg. cab, ext. cab, crew cab? is this for the front seats or back seats? do you have solid bench seats, 60/40 split, buckets?
    hotfish
    hotfish
  • Who's Online   5 Members, 0 Anonymous, 815 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
