NON-HD 6.0L Exhaust Help !!
Ive got a 2000 GMC 2500 non-hd with the 6.0L and I have been putting off getting exhaust because of the problems I hear can occur with the wrong configuration. I am wanting to put duals on and dont know wheither to get a couple mufflers or even a single -dual 3" in/out. and have my local muffler guy run the rest and if so what kind of mufflers to get. Or if i should go for some expensive kit, which i am wanting to stear away from. I was going to just get a couple flowmasters, but i am worried about the effects. I am wanting a good solid sound. I can find everything about the 5.3, but not much about the 6.0, someone please help !!!
Welcome to the club... well after much searching, I found the same thing, nothing for the 6.0... I ended up getting the cat back system for the 2500HD (Flowmaster 50 series duel 3" in, single 3.5" out) then had a muffler shop weld it up, since I guess the HD's are 3" tubing. Sounds good, just not loud enough for me! I think I am eventually gonna cut that off, go with an x-pipe and duel original 40 series.
A lot of people talk about the 2k rpm resonation... I haven't noticed it yet.
I would say go to a shop and see what they can do for you. You are limmeted by only your imagination... and your wallet!
Well thanks for the help... everyone just has different things to say but noone has really experimented around here with the 6.0, they all just know what they "hear" and everything "hears" different.... Thanks for your input though
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
