Adjustable headrests
I drove a Yukon that had ajustable headrests that not only adjust up and down, but also fore and aft (tilting effect). Is this only offered on the Denali? I wish they came on my Tahoe LT and was also wondering where I could get a set.
thanks.
My friend's 03 Yukon SLT has them, so I would think they are available on Tahoes after 03.
You would have to replace the entire seat, along with upgrading the wiring and switches to the memory seats.
Yeah, Shaners you are right. I was thinking about the power ones. The ones like yours are a direct replacement.
Maybe he is talking about the power ones... I dunno??? :jester:
I'm talking about the manual racheting ones. '04 Tahoe LT's (leather) don't come with them. Maybe I could pick up a pair and swap out the ones I have?
Got 'em on the '01 Yuk XL. Vinyl covered even with 1SD pack.
far as i know, only the 03-04 escalade (all caddie trucks and suv), denali, and h2 came with the manual ratcheting headrest. :thumbs: it wasn't even an option on my 03 yukon. if you want one, look on ebay. i bought one from ebay that came out of h2 and fits and works perfectly. not bad for h2 leather headrest for around $50.
You mean these? I bought them on ebay these ones are Hummer H2 tilting headrests. I had mine done up with my upholstery, I have 1 extra set left. If you are interested in them I can let them go for 100$ for the pair, and I will include shipping.
The ones I have are greyish leather.
far as i know, only the 03-04 escalade (all caddie trucks and suv), denali, and h2 came with the manual ratcheting headrest. :cheers: it wasn't even an option on my 03 yukon. if you want one, look on ebay. i bought one from ebay that came out of h2 and fits and works perfectly. not bad for h2 leather headrest for around $50.
We just got a truck in that has the ratcheting headrests.
It is a 2002 GMC SLT, and I think this is the key here, 8-way power seats with the memory functions.
That has been a mystery to me also. I owned a 99 Silverado LT equiped with the tilting headrest from the factory(listed in the options list). I now own a 2003 GMC SLT loaded with same options. My headrests do not tilt. I asked the dealer about this option and they all had the same answers.
Most 99 Sierra-Silverado SLT-LT packages included them(including Tahoes and Yukons). Since then, newer model years are showing up with them sporadically and there is not an option code to order them.
I am as confused as you are. I miss the tilting option that my older truck had. It may be a hidden option. In the good old days of 99 the locking spare tire was standard and now its an option. I also learned that one the hard way.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
