HID lights
I've seen some threads on this subject, but really not that much information or experience posted. I am interested in HID headlites for my o4 Yukon XL. I know you can get bulbs. Is it better to upgrade to Denali projector lights when using HID bulb? Do you use on low or high beam or both. I know there is a glare problem w/ conventional housing.
Does anyone know if an entire system, similar to ones available for Chevy trucks will be available anytime soon? Thanks
dont really know of any vendors,I had a bohmen kit that was very nice.I think sylvania makes a kit also.The bi-xenon kit for highs/lows is quite a bit higher and really unessessary.The low beams are just as bright if not brighter then high beams,making the high beams unessesary unless you need them to pass inspection.But there a flick trick mod.That makes your low beam flick to make it look like it went to a high beam.
I woudlnt put HID in both hi and low. HID in the low beams alone will be plenty sufficient!! As far as vendors, check out these:
www.polarionlighting.com
www.misterjung.com
I have a Mr. Jungs kit. Hella ballasts and retroed Osram bubls. The Xenarc kit was too expensive back when I bought my HID kit. ou just have to make sure you get good ballasts!!!! Mr. Jungs uses Hella and Polarion Lighting uses Phillips. Those are the only 2 brand ballasts I would buy.
I just put the HID's in my truck yesterday. You wont need the Highbeams. Hell you probably wont even use the highbeams anymore. The amount of light the HID's put out more than makes up for it. Just make sure you aim the headlights correctly.. You can blind someone with these lights if you have them cranked up in the air
  • 4 months later...
New to the site but like what I see. Can get in alot of trouble here!
Any of you guys using the 4700k McCulloch HID conversion kit? From what I have read thru searches most are very happy with it although some have heard that they have higher failure rates yet I have yet to read of a failure directly. I'm not crazy about the blue bulbs but the price is right on eBay McColloch 4700k on eBay.
Thanks,
Brendan
Thanks. I not looking for anything that high k-wise. I would prefer 4300 but will settle for 4700. I want performance, not looks. The more light the better.
Arent the bulbs that come with the McColluch conversion tinted blue? Not too crazy about that.
i have a 6000K McCulloch kit and i love them! i have a 96, so i put in the angel eyes headlights and the hid kit, and the light output is GREAT!!!! i'll never go back to a stock kit and any car i'll ever drive will have HID's.
i'd suggest gettin the Denali headlight housing with the projectors and then get low beam HID's. u won't even use ur highs again, i certainly have never used my highs, EVER!!!
BTW, MisterJung's is not there anymore, too many people got scamed...
Aj
here is a pic of the 8000K, compared to the stock fog lights
sorry its kind of fuzzy, it was freezing when I took that pic and I think my hands were shaking a bit...
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 950 Guests (See full list)
