I'm happy with my VOLANT system,however I did change out the filter VOLANT supplies and replaced it with a K&N (part no.RU-2800)only because of using K&N's in all my other trucks and there reputation and quality.
You can also get an air scoop that scoops air from right behind your RH side tow hook,but it does make it a little more louder when you "get on it" I ended up removing mine,just personal preference though.
I also like the idea that the VOLANT system gets all of its air from outside the engine compartment,the K&N's FIPK kit is open underneath the hood and sucks some air in from there and hot air is not what you want,it also leaves the air filter wide open to get dirtier faster.
I have the K&N 77 series with the polished tube. The Tube looks really good, and performance wise you will definatly feel it and hear it. Added plus mine added 2 MPG and i haven't changed my driving habits :D it's hard not to try it out.
I have not had any experience with the other intakes but as far as hot air is concerned mine has a heat shield that takes the air the farthest from the engine. also for cleaning it no big deal, i see it everytime i open the hood so i know if it is dirty right away. you don't have to do the full cleaning everytime, just use a LITTLE air pressure and blow it out from the inside.
Only Drawback on this system is the chrome air filter cap the emblem K&N is hidden from veiw.
:thumbs:
