22" Magnaflow
Just installed a 22" Magnaflow Muffler with new dual exit pipes today.
3" in and dual 2.25" out with 3" stainless tips.
Exactly what I was looking for. Not loud at all, almost silent at idle and cruise, but very deep and a bit throaty under acceleration.
I found a local shop that did a very nice job with the installation and the installed price was $100 cheaper than I could have bought the kit for with the 18" muffler online.
Kinda sounds like you are driving a Vette instead of a truck. It lets you know it is there, but in a suttle kind of way.
:thumbs::smash:
Pics. I can figure out, but I have no way of getting a sound clip.
The camera I have is of the same vintage of one that took pictures of Billy the Kid and my computer is a Comodore 64!! LOL :thumbs:
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,025 Guests (See full list)
