dash is flaking
I have a 99 silverado ext cab z71 that has a paint peel on the dash beside the grab handle on the passenger side to the right has anyone else had this?Dealer told me that it would have to be fixed with some process that invovled dyeing the dash instead of just touching it up or fixing it with what i thought was paint ont he dash .i have had this prob for a couple years right out of warranty of course,and have put clear nail polish around the bad spot to prevent it peeling farther.just wondering if anyone had this happen and how much for repair?i am kinda getting tired of looking at it.my truck was made april 99 so maybe this is something gm has fixed
I bought my truck in Apr 99, and it's doing the same thing, only not in any highly visible areas yet. Do a search in this forum, it's a pretty common problem, even on newer models than ours. Sorry I don't have a fix for ya, but if you check the phone book you can probably find a trim/interior repair person to do it cheaper than the dealer. Most dealers sublet that kind of work out to these guys anyway, the dealer I work at uses a company called New Life Trim Repair...a guy with a pickup and a toolbox full of paints and goo and stuff.
If you want to redo the whole dash yourself, it comes out pretty easily from what I understand. :banghead:
Went through the same thing with my 03 except mine was flaking near the vents at the base of the windshield. Took the truck to the dealer and the did the re-dye thing and guess what?......I now have several bubbles in the dash from the re-dye process not working - and NO I haven't used anything on the dash since I got it back 3 weeks ago. Some on here will try to tell you it's what's you're using on your dash but to me it seems more like there's a lot more than just a few having the same issue. I talked to the dealer again today and I have to take the truck in on Monday and the Service Manager is going to look at the dash and he's going to replace it not re-dye it. I gave them their chance and the re-dye didn't work so now I want a new dash. See the link below for the discussions that went on - good luck!!
http://www.gm-trucks.com/forums/index.php?...ash,and,peeling
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 950 Guests (See full list)
