Trailer Lights
After getting a $105 ticket 2 weeks ago for the lights being out on my trailer, I finally decided to find out what was wrong. It turns out I had a number of problems with both my truck and trailer. I ended up putting a new plug on the truck and replacing all the lights on my trailer. Everything now works great except that when I step on the brakes, all the trailer lights go out. I'd like to get this fixed because tomorrow, I will be going through the same town that gave me the ticket. Any ideas?
I had the same problem with a 89 bronco II, but I cant remember how I fixed it. I would double check your wiring and make sure something isn't grounding out somewhere along the lines. There is also a wiring kit out there that doest require any cutting it just plugs into the existing harness behind the rear bumper. but I think it only works on late model vehicles. thats all I can think of right now, good luck :thumbs:
I've got to hook up a wiring kit on my rig as well cause its set up to tow trailers with electric brakes :seeya:
I had a similar problem. I have a tilt trailer and had to run a ground wire between the two halves of the trailer. Also check and see if your bulbs making proper contact. to do that have put something on the brake pedal to keep the light on and then go wiggle and push on the bulb. If it works intermitantly then its your light housing. I had to modify my trailer lights to hold tighter to the bulb so it would get enough contact to operate.
It's a tilt trailer, but it has never been tilted because it has a gate on the back. I thought it was a ground too, and I noticed last night that the ground wire on the trailer harness was never hooked up from the factory and I've been grounding through the ball for 3 years. So I pulled it out from the tongue channel and grounded it to the tongue lip. Problem still existed. So, what you are saying is to run the ground back to the end of the tongue channel and ground it to the trailer frame instead of the tongue? I'll try running a jumper wire from the ground I did last night to the frame and see if the problem goes away.
I had to add a jumper across the hinge of the tilt trailer. The hinge tends to corrode and doesn't have enough continuity for a good ground.
I ran a ground directly to the trailer frame beyond where the trailer would tilt. The problem is now fixed and everything works perfect. Thanks for the help.
Great!!! Your hired.
I'll expect you by noon tomorrow to re-wire my trailer. :seeya: It's not a tilt, so you should be able to rewire it standing on your head! :thumbs:
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,163 Guests (See full list)
