Where is my problem??
I have a kenwood HU going to an Orion 500.2 amp running series parrallel to 2 audiobahn subs. It doesn't hit nearly as hard as I want. Is the way the subs are wired the best or is there another way. Or should I get new subs?
Thanks!!
Thanks!!
I have a couple ?'s for you:
1) What's the lowest load your Orion will play at? (4/2/1 ohm mono)
2) What's the voice coil config of your subs? (4 ohm DVC or 2 ohm DVC)
Here's a few wiring diagrams that may help:
It would also help to know what type of enclosure you are using. Ported/sealed? What are your subs requirements? Do you have them under the rear seat? I know some folks have shoehorned 10s behind the rear seat, and had them sound OK, but not up to their potential.
The subs are 4 ohm DVC currently wired for 4 ohm load. My orion will do 4 mono and 2 stereo?
I have them in sealed boxes currently firing down under the rear seat, as per a suggestion from a local sound shop.
so you have it going into the amp as a 4 ohm load? but are you using 1 or 2 channels? if you're only using 1 that could be your problem. take the speaker wire out and bridge it. that will give you the output of 2 ohm. i had a fosgate amp that was worded like that. it said not to give it below a 4 ohm mono load, but after i got to thinking and done some talking with people smarter than i am, they said i could give it the 4 ohms and the amp would see a 2 ohm mono load. and that wouldn't hurt the amp.......if all the babbling made sense :thumbs:
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 483 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
