Rear Speakers
Greetings all,
just signed on the forum, cauzz I saw this question pop up and it's what I'm looking for.
I need to get at those rear speakers in my 90 GMC Sierra reg cab as well. All the install places I've spoke to says that even their experienced installers will end up busting that trim. I figure If the trims gonna break, I may as well do it cuzz I can break stuff really good and save myself $45 a quarter hour.
IF anyone scares up any tricks to getting this done let me know.
Thanks!
C
ahh crap I forgot to look sorry bout that :cheers: I'll write meself a note this time and let ya know what I did tommorow :D I've ripped apart a few :sleep: interiors so it should be fairly easy I hope. worse case I break the trim myself and I can tell you guys what NOT to do :crackup: but right now it's time to :cheers:
:cry:
:cry: yeah thats pretty much what I just did :cheers: That rear trim piece is pretty hard to get off. I used a tool I bought for popping molding clips off with but a small pry bar would most likely work just as well :cheers: I started by pulling the end trim out just far enough to get at the end clip on the top of the trim panel. and just slowly work the clip out but dont put too much pressure on one spot move back and forth across the clip. It made some sounds like the whole panel was gonna break but it didn't. there are spots for five clips on the top row but there were only three clips on the top row. I'm guessing so you can shift the clip position in case one gets broken :D witch is what I'll be doing when I put the panel back on :flag: I'm sure there is a tool out there somewhere that would make this easier but I managed just fine :D the bottom row of clips I popped off by going down from the top of the panel with a LARGE flat head screwdriver (about a 3/8" wide tip) once you get it snugged up tight to the first clip carefully twist the screwdriver little by little moving across the clip back and forth so as not to put too much stress on one spot at a time (I broke 1 by being impatient so take your time :crackup: ) btw I started on the end and worked my way across the clips :sleep: It took me a total of mabye 5 to 10 minutes to remove the panel after that you'll have to remove the side panels as well as pop the platic grommets from the carpeting. tools for removing door and panel clips are fairly cheap and I would reccomend picking one up for anyone who plans on doing interior work :nono: might save you a couple bucks in clips too :)
Hope this helps you guys out and I hope I didn't forget anything
good luck :sick:
i broke the top row of clips getting mine off. and i used a big honking flathead screwdriver. i tried the trim removers and the "official" tools, but the big screwdriver got the job done in the end. good luck with it
    RichardRS
    RichardRS
  • Who's Online   1 Member, 0 Anonymous, 805 Guests (See full list)
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
