cabin filter???? 2003
I may be wrong about this, but I recall reading on here a while back that GM dropped the cabin filters for the 03+ model years. Can anyone confirm this? Damned cost cutting -- that's a feature I like about my 00... that and the under hood light that I think they also cut for 03+.
Yep, they did not put one in on the 2003 models. You are right - it is cost cutting...things like the underhood light, cabin filter, etc. that they removed but the price of the truck goes up...now it is $15 for a spare tire lock that came standard on the 2002 and prior models.
:thumbs:
putting that screw back in right over the transmission hump is a PITA
why does everyone complain about that stupid underhood light? it is basically useless anyways - I just keep a flashlight in the truck and use that if I need to look under the hood at night.
although i did like the in cabin air filter, i thought that i heard there were a lot of problems with the heat/ac cause people wouldnt change the filters...
I have now found the hump screw does not even need to be loosened and only the right 2 need to be removed then the housing will pull down entirely out of the way. Then the strap holding the filters also does not need to be unscrewed, just use a flat blade driver to pop the top of the latch off then move it out of the way ... only takes abt 10mins to replace the filters now :thumbs:
Do all of the 1999 Sierra models have the filter? I assume it is located under the dash, behind the black plastic cover that is under the glove box and is held on by three 7mm screws. Am I correct in my assumption? Is the filter visible or is it encased in something?
Thanks
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,179 Guests (See full list)
