605 ft lb of torque and 310 hp
Is the 605 ft lbs of torque and 310 hp only available in first and fifth gear just like the 2004 where as the 590 ft lb of torque is availabe only in first and fifth gear and you only have 520 ft lb of torque 2-4 gear.
:thumbs:
im not an engineer but the lower ratings in 1st and 5th will probably stay, this is probably to increase transmission life in 1st gear and overdrive when the full 605 ft lbs of torque is not an absolute neccessity as opposed to taking a grade in 3rd or 4th going 50-60 just my take on it :thumbs:
    bellssn690
    bellssn690
  • Who's Online   3 Members, 1 Anonymous, 886 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
